Empty filter causes IndexOutOfBoundsException
Key: GEOS-3228
URL: http://jira.codehaus.org/browse/GEOS-3228
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.5
Environment: Tomcat 5.5, Java 1.5.0, WinXP
Reporter: Mark Leslie
Assignee: Andrea Aime
Priority: Minor
Using the default war package sample data (1.7.5), go to the demo page and select WFS_GetFeatureBetween, yielding:
Remove the filter value, but leave the key:
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at org.geotools.xml.EMFUtils.set(EMFUtils.java:226)
The resulting error seems to be a result of GEOS-1914, but it's unclear why the empty filter fails (instead of being interpreted as no filter for example).
