Rest API throws error when adding featuretype without geometry
Key: GEOS-3234
URL: http://jira.codehaus.org/browse/GEOS-3234
Project: GeoServer
Issue Type: Bug
Components: Configuration, PostGIS, REST
Affects Versions: 1.7.5, 1.7.4
Reporter: piebe
Assignee: Justin Deoliveira
When using the REST API to add a new featuretype from a postgis database table and this table does not contain a geometry column a null pointer exception is thrown. (Maybe related: a null pointer exception is thrown if a geometrycolumn is available but the table is empty)
2009-07-06 14:50:51,562 INFO [org.geoserver] - Loaded feature type
'thema_huisaansluitingen', disabled
2009-07-06 14:50:51,609 ERROR [org.geoserver.rest] - :null
2009-07-06 14:50:51,609 DEBUG [org.geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.NullPointerException
at
org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:329)
at
org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:118)
at org.restlet.Finder.handle(Finder.java:296)
at
org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at
com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at
org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at
at
at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NullPointerException
