Allow Wicket configuration (development/deployment) to be configured the usual GeoServer way
Key: GEOS-3245
URL: http://jira.codehaus.org/browse/GEOS-3245
Project: GeoServer
Issue Type: Bug
Components: Wicket UI
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0-beta2
Currently the configuration is hard coded in a Spring application context file and hard to modify for the admin.
The attached patch makes it so that the config is read the usual geoserver way, that is, enviroment, system variable, or web.xml. Also, the code defaults to deployment mode, so that nothing extra needs to be set in the various GeoServer packagings in order to just run GeoServer.
The developers interesting in having GeoServer work in development mode can add -Dwicket.configuration=development to the command line running GeoServer. A doc change is needed too... maybe in the ecilpse-guide, below the "setting the data directory" paragraph?
