[Geoserver-devel] [jira] Created: (GEOS-3257) StyleEditPageTest and StyleNewPageTest fail on Windows
                 Key: GEOS-3257
                 URL: http://jira.codehaus.org/browse/GEOS-3257
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
            Reporter: Rini Angreani
            Assignee: Andrea Aime
            Priority: Critical
Running org.geoserver.wms.web.data.StyleEditPageTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.985 sec <<< FAILURE!
Running org.geoserver.wms.web.data.StyleNewPageTest
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 5.61 sec <<< FAILURE!
This happened to me and my colleague. We're both using Windows.
In StyleEditPageTest, it fails in testLoad():
tester.assertModelValue("theForm:sld:editor", style);
When debugged, the WicketTester value has "\r\n" as line separator, whereas the style file value only has "\n" as separator.
According to Ben:
They should be comparing XML using XMLUnit. A string comparison is doomed to fail on Windows because svn is
correctly configured to use native line endings.
