Newly created style yield Java stack trace on deletion
Key: GEOS-3258
URL: http://jira.codehaus.org/browse/GEOS-3258
Project: GeoServer
Issue Type: Bug
Components: Wicket UI
Affects Versions: 2.0-beta2
Reporter: Mike Pumphrey
Assignee: Andrea Aime
Fix For: 2.0-RC1
Using latest trunk bin version (7/13/09)
Steps to reproduce.
* Go into UI -> Styles
* Create new style (use the default)
* Submit
* Select newly created style and Remove
* Error!
Root cause:
java.util.MissingResourceException: Unable to find resource: confirmRemoval for component: headerPanel:removeSelected [class=org.geoserver.wms.web.data.StylePage$2]
at org.apache.wicket.Localizer.getString(Localizer.java:266)
at org.geoserver.web.GeoServerApplication$GeoServerLocalizer.getString(GeoServerApplication.java:285)
at org.apache.wicket.model.StringResourceModel.getString(StringResourceModel.java:501)
at org.apache.wicket.model.StringResourceModel.load(StringResourceModel.java:633)
at org.apache.wicket.model.LoadableDetachableModel.getObject(LoadableDetachableModel.java:114)
at org.apache.wicket.model.StringResourceModel$AssignmentWrapper.getObject(StringResourceModel.java:230)
at org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow.getWindowOpenJavascript(ModalWindow.java:967)
at org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow.show(ModalWindow.java:286)
at org.geoserver.web.wicket.GeoServerDialog.showOkCancel(GeoServerDialog.java:77)
at org.geoserver.web.data.SelectionRemovalLink.onClick(SelectionRemovalLink.java:49)
at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:65)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1220)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1297)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1399)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:529)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:124)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
