[Geoserver-devel] [jira] Created: (GEOS-3277) Improve error handling for WMS GetMap requests so only a well known set of rendering exceptions are ignored
                 Key: GEOS-3277
                 URL: http://jira.codehaus.org/browse/GEOS-3277
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
    Affects Versions: 2.0-beta2
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-RC1
See discussion here [http://www.nabble.com/WMS-rendering-eats-all-exceptions-td24543043.html\]
Basically, {{StreamingRenderer}} defers all the exception handling to it's {{RenderListener}}s. It does even for {{Throwable}}.
GeoServer's WMS GetMap request means to ignore some kind of rendering errors in order to make a best effort at rendering the most possible out of a dataset. So it means to ignore reprojection exceptions, for example.
But the side effect is that all and every exceptions are being ignored, producing "false positive" getmap responses where some exception that shouldn't be ignored is thrown.
We can add with no performance penalty a listener that checks if the exception is one of a well known set of exceptions that we're interested in ignoring, and if not fail and hence throw a ServiceException instead of returning a false positive success response.
