[Geoserver-devel] [jira] Created: (GEOS-3279) GeoServer appends file urls with full path
                 Key: GEOS-3279
                 URL: http://jira.codehaus.org/browse/GEOS-3279
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.0-beta2
         Environment: CentOS, GeoServer trunk, Shapefiles, Tomcat
            Reporter: Ivan Willig
            Assignee: Justin Deoliveira
GeoServer is appending the relative path of shapefiles with their full path. Also, I am not sure if this is important, but I have noticed that GeoServer is not appending the path with the currently configured that data folder, but what would be the default
Heres an example.
Lets say the path of the data_dir is
/var/lib/geoserver_data/data/
and the shapefile is at
/var/lib/geoserver_data/data/data/shapefile.shp
and GeoServer is configured at
/opt/tomcat/webapps/geoserver/
I enter file:data/shapefile.shp
and GeoServer saves the url as
/opt/tomcat/webapps/geoserver/data/data/shapefile.shp
