Multiple levels of logic operators
Key: GEOS-328
URL: http://jira.codehaus.org/browse/GEOS-328
Project: GeoServer
Type: Bug
Components: WFS
Versions: 1.3.0-beta2
Reporter: dblasby
Assigned to: Chris Holmes
Fix For: 1.3-rc1
I posted this issue to the geoserver list, but I think it's more
appropriately a GeoTools question. Not familiar enough with the lists to
know whether this should go to users or devel, so I apologize in advance
if this is in the wrong spot.
It seems that Filters sent to GeoServer which have > 2 levels of nested
logic fail. For example, the following structure will fail:
<And>
<Or>
<Not>
<PropertyIsEqualTo.../>
</Not>
</Or>
</And>
With the following error:
Attempted to construct illegal filter: Logic Factory got an end message
that it can't process.
In org.geotools.filter.LogicSAXParser.start(...), a new LogicSAXParser
is created even if the existing one is not null, effectively limiting
the logic depth to 2 levels. Changing the line:
logicFactory = new LogicSAXParser();
to:
if (logicFactory == null) {
may solve the issue, but I'm not at all familiar with the GeoTools code
(I've only just looked at it yesterday) so my suggestion may have
ramifications of which I am unaware. I've also not tested it...
Any thoughts? Is the logic filter depth meant to be limited to 2
levels? Is my analysis correct?
John
actual test request (for UserBasic standard config):
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="states" >
<Filter>
<And>
<Or>
<Not>
<PropertyIsEqualTo>
<PropertyName>STATE_NAME</PropertyName>
<Literal>daveville</Literal>
</PropertyIsEqualTo>
</Not>
<PropertyIsEqualTo>
<Literal>belongadave</Literal>
</Or>
<PropertyIsEqualTo>
<Literal>Wisconsin</Literal>
</And>
</Filter>
</wfs:Query>
</wfs:GetFeature>
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/geoserver/data/capabilities//wfs/1.0.0/OGC-exception.xsd">
<ServiceException locator="org.vfny.geoserver.util.requests.readers.XmlRequestReader">
org.xml.sax.SAXException: Attempted to construct illegal filter: Logic Factory got an end message that it can't process.
</ServiceException>
</ServiceExceptionReport>
If you want more information on JIRA, or have a bug to report see:
