[Geoserver-devel] [jira] Created: (GEOS-3285) While trying to save a feature-type from a PostGIS datastore, GeoServer throws a nasty error.
                 Key: GEOS-3285
                 URL: http://jira.codehaus.org/browse/GEOS-3285
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.5
         Environment: Ubuntu 9.10, Sun Java, Tomcat, and GeoServer 1.7.5
            Reporter: Ivan Willig
            Assignee: Justin Deoliveira
Original I attempted to add this feature type via the the rest interface. Everything seemed to work okay. However, when I changes the style and tried to save GeoServer, it blow up. Here is the stack trace.
java.lang.NullPointerException
  at org.vfny.geoserver.config.FeatureTypeConfig.toDTO(FeatureTypeConfig.java:443)
  at org.vfny.geoserver.config.DataConfig.toDTO(DataConfig.java:375)
  at org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:68)
  at org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
  at java.lang.Thread.run(Thread.java:619)
I am not sure if something went wrong when I was adding via the REST API. During the configure process via rest, GeoServer did not complain via the logs. Its only when I try to save in the UI, that GeoServer throws this error. The layer that I am using is rather large, so please let me know if I should make it available for testing.
