[Geoserver-devel] [jira] Created: (GEOS-3287) org.opengis.coverage.CannotEvaluateException when trying to execute GetFeatureInfo outside the bounds a DEM coverage
                 Key: GEOS-3287
                 URL: http://jira.codehaus.org/browse/GEOS-3287
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.4
         Environment: Ubuntu Linux 9.04, kernel 2.6.28-14
Java(TM) SE Runtime Environment (build 1.6.0_14-b08), Java HotSpot(TM) 64-Bit Server VM (build 14.0-b16, mixed mode)
apache-tomcat-6.0.18
            Reporter: Daniele Bonfatti
            Assignee: Andrea Aime
When I try to execute a GetFeatureInfo outside the bounds of a DEM coverage an exception occurs:
org.vfny.geoserver.wms.WmsException
  at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.execute(AbstractFeatureInfoResponse.java:410)
  at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:145)
  at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:94)
  at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.execute(GetFeatureInfoResponse.java:97)
  at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:699)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:394)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
  at java.lang.Thread.run(Thread.java:619)
Caused by: org.opengis.coverage.CannotEvaluateException: The position at which we should evaluate the coverage does not fall within the coverage's bbox
  at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.execute(AbstractFeatureInfoResponse.java:357)
  ... 55 more
     [ http://jira.codehaus.org/browse/GEOS-3287?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-3287:
Simone, that is _not_ the expected behaviour, this is WMS, not WCS. There is nothing in the spec demandind such an exception, the vector side just returns nothing, which is a much better behaviour, makes coding the client simpler and is consistent with the GetMap behaviour. Or shall we also start throwing exceptions in GetMap when a user asks to paint an area outside of the coverage?
                Key: GEOS-3287
            Project: GeoServer
         Issue Type: Bug
           Assignee: Simone Giannecchini
            Fix For: 1.7.6, 2.0-RC1
  ... 55 more
