Cite engine compiles only under Mac
Key: GEOS-3288
URL: http://jira.codehaus.org/browse/GEOS-3288
Project: GeoServer
Issue Type: Bug
Components: CITE
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0-RC1
As per discussion on the ml, there is a dependency to tools.jar that needs to be removed on Mac, but is needed on other systems.
This calls for a profile, but not sure it's actually doable, as it demands to add something when the system is not a mac, or to remove something when the system is a mac.
Afaik profiles are additive, so the latest is not possible, and I'm not sure how to make an activation check that excludes a OS.
