[Geoserver-devel] [jira] Created: (GEOS-3305) GeoServer trunk does not correctly match a shapefile's projection to the correct epsg
                 Key: GEOS-3305
                 URL: http://jira.codehaus.org/browse/GEOS-3305
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.0-beta2
         Environment: Ubuntu GNU/Linux. Sun Java, Tomcat, GeoServer was built from trunk and Shapefiles
            Reporter: Ivan Willig
            Assignee: Justin Deoliveira
GeoServer fails to correctly assign the correct projection to a shapefile with a valid .prj file.
The Shapefile's .prj looks is::
GEOGCS["GCS_WGS_1984",
    DATUM["WGS_1984",
        SPHEROID["WGS_1984",6378137,298.257223563]],
    PRIMEM["Greenwich",0],
    UNIT["Degree",0.017453292519943295]]
and the correct definition for ESPG:4326 is
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
However, I think GeoServer should be able to recognize this as 4326. If you need a shapefile that cause this bug please contact me as I cannot distribute these shapefiles.
Thanks guys.
