Setting protected modificator in catalog beans
Key: GEOS-3313
URL: http://jira.codehaus.org/browse/GEOS-3313
Project: GeoServer
Issue Type: Improvement
Components: Configuration
Reporter: Emanuele Tajariol
Assignee: Justin Deoliveira
Attachments: 20090730_trunk_src_main.diff.gz
In order to be more hibernate-friendly, beans need to have setters and getters for all of their fields.
They also need an empty constructor.
The provided patch modifies the following classes
M src/main/java/org/geoserver/config/impl/GeoServerInfoImpl.java
M src/main/java/org/geoserver/config/impl/ServiceInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/CoverageStoreInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/LayerInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/DataStoreInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/ResourceInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/LayerGroupInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/CoverageInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/NamespaceInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/StoreInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/FeatureTypeInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/WorkspaceInfoImpl.java
M src/main/java/org/geoserver/catalog/impl/StyleInfoImpl.java
- adding the "protected" keyword to the fields which have no modificator (being in that way package private);
- adding a protected empty constructor where needed;
- adding protected setter where needed.
