[Geoserver-devel] [jira] Created: (GEOS-3319) Rounding error
Rounding error
                 Key: GEOS-3319
                 URL: http://jira.codehaus.org/browse/GEOS-3319
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.6
            Reporter: Jonathan
            Assignee: Andrea Aime
            Priority: Trivial
Upgraded from 1.7.5 to 1.7.6 - I did this by simply deleting all the contents of the 75 except the data_dir and replacing with 76. (binary installs both).
I neglected to remember there were a couple of plugins I should also have downloaded (mysql and pyramids), so when i started geoserver I ended up with the top-left three green bars no all red.
The bug is that the green part was 87% and the red part 12%. 1% appears to have been lost to rounding.
