Show errors if config is broken when the form loads
Key: GEOS-3349
URL: http://jira.codehaus.org/browse/GEOS-3349
Project: GeoServer
Issue Type: Improvement
Components: Configuration
Affects Versions: 2.0-RC1
Reporter: David Winslow
Assignee: Justin Deoliveira
Forms containing erroneous fields do not show error messages until the user tries to submit. Examples of situations in which this might occur are when using a data directory that was created under looser constraints (an older version of geoserver, perhaps), or when creating a new data store under specific conditions (if the underlying file for a coverage store has a . in its name, then a . will be included in the default value for the layer title, resulting in a validation error).
