[Geoserver-devel] [jira] Created: (GEOS-3351) RESTConfig allows configuration that would be blocked by UI
                 Key: GEOS-3351
                 URL: http://jira.codehaus.org/browse/GEOS-3351
             Project: GeoServer
          Issue Type: Bug
            Reporter: David Winslow
            Assignee: Andrea Aime
if I upload a file via restconfig, I can give the resulting layer a name with a period in it. If I tried to do this in the web ui, then I wouldn't be able to (and similarly, trying to edit the layer after adding it via rest results in a validation error, even if I don't actually change any values.)
