[Geoserver-devel] [jira] Created: (GEOS-3359) Silent serialization failure on coverage data
                 Key: GEOS-3359
                 URL: http://jira.codehaus.org/browse/GEOS-3359
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.0-RC1
            Reporter: David Winslow
            Assignee: Justin Deoliveira
I have a data directory where any time I modify a coverage, the coverage.xml ends up broken (the serializer seems to be bombing out partway through writing the file; my inspection of the code suggests this is due to a null pointer for the SRS field on the coverageinfo object). I can provide the afflicted data directory or a sample coverage.xml, but I need to keep it inside of OpenGeo.
