gs 1.7.6 installer does not set JAVA_HOME in Windows 7
Key: GEOS-3360
URL: http://jira.codehaus.org/browse/GEOS-3360
Project: GeoServer
Issue Type: Bug
Components: Windows Installer
Affects Versions: 1.7.6
Environment: Windows 7 Build 7100, JRE 1.6.16
Reporter: sophia parafina
Assignee: Andrea Aime
Windows installer asks for path to JRE/JDK, but does not set JAVA_HOME. Service fails to start.
Workaround is to set JAVA_HOME manually
