location of capabilities/ directory
Key: GEOS-337
URL: http://jira.codehaus.org/browse/GEOS-337
Project: GeoServer
Type: Improvement
Components: Configuration
Versions: 1.3.0-beta3
Reporter: dblasby
Assigned to: dblasby
Fix For: 1.4
After the conf/ configuration re-org so they could be pointed to directly by the geoserver_data_dir, I found that all the configurations required the same capabilities/ directory.
I just copied the capabilities/ directory into each configuration - a better idea would be to move this to the WEB-INF/ directory so there's only one to maintain.
Consider doing this - make sure that there's no upgrade problems and capabilities really isnt changing.
cholmes:
Hmmm... I wonder if we could/should put the capabilities directory in a
more static place? Is it the only thing in the data dir that will
always be the same across configs? Because I think we will have to add
more, like when we add new ogc services.
For more information on JIRA, see:
HI,
I am sending this email directly since I am having problems with the
list. Can you give some directions on how to use your classes to
encode gif images, since we are trying to use them in the WCS branch.
Thanks, simone.
Key: GEOS-337
Project: GeoServer
Type: Improvement
Reporter: dblasby
Fix For: 1.4
cholmes:
This SF.Net email is sponsored by: NEC IT Guy Games.
Get your fingers limbered up and give it your best shot. 4 great events, 4
opportunities to win big! Highest score wins.NEC IT Guy Games. Play to
win an NEC 61 plasma display. Visit http://www.necitguy.com/?r=20
Geoserver-devel mailing list
