[Geoserver-devel] [jira] Created: (GEOS-3373) 1.7.6 installer does not set write permissions on the log file file directory and geoserver does not start
                 Key: GEOS-3373
                 URL: http://jira.codehaus.org/browse/GEOS-3373
             Project: GeoServer
          Issue Type: Bug
          Components: Windows Installer
    Affects Versions: 1.7.6
         Environment: Windows 7 Build 7100, JRE 1.6.16
            Reporter: sophia parafina
            Assignee: Andrea Aime
The windows installer does not set the write permissions on the log directory which prevents geoserver from starting. This is probably because the default directory is \Program Files\Geoserver. This might also affect the data_dir since it is also under \Program Files
Work around is to manually set permissions for user to write to the log directory. Start geoserver manually from the startup.bat file and not as a service.
