[Geoserver-devel] [jira] Created: (GEOS-3377) Save failures result in corrupted data directory and are not reported in the UI
                 Key: GEOS-3377
                 URL: http://jira.codehaus.org/browse/GEOS-3377
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
            Priority: Blocker
             Fix For: 2.0-RC2
When an error occurr in the XStream persister two bad things happen:
1) the file is corrupted, and won't be loaded at the next restart
2) the error is not reported at the UI level
1) means the configuration will be lost (if a datastore one is lost, everything attached to it will die as well). This is not good, especially if one is just editing something existing.
It's probably cautious to have the XStreamPersister write to an in memory buffer first, and dump on disk later? Or write on a new file, and then rename it to overwrite the older.
On this topic, here is an interesting discussion http://stackoverflow.com/questions/595631/how-to-atomically-rename-a-file-in-java-even-if-the-dest-file-already-exists which
points to this package http://commons.apache.org/transaction/, that looks _very_ interesting (atm we have no transaction abilities on the fs, but it seems we could add some?)
2) is grave because the user may spend a lot of time building atop the configuration that was not saved just to discover the loss of its work after the restart.
We had a few similar reports on the ml, people working on the config to discover it was gone afterwards.
