Problem during SVG generation
Key: GEOS-338
URL: http://jira.codehaus.org/browse/GEOS-338
Project: GeoServer
Type: Bug
Versions: 1.3.0-beta3
Environment: GNU/Linux Ubuntu Hoary - Java 1.5 - Tomcat 5.5.9
Reporter: Adrien Anselme
Assigned to: Chris Holmes
Attachments: dj.xml, dj.xsd
PNG generation works well for the attached file, but SVG raises the following exception :
<ServiceExceptionReport version="1.1.1">
<ServiceException code="">
java.io.IOException: UNCAUGHT exception: No SVG Feature writer defined for class com.vividsolutions.jts.geom.Geometry
at org.vfny.geoserver.wms.responses.map.svg.SVGWriter.setGeometryType(SVGWriter.java:157)
at org.vfny.geoserver.wms.responses.map.svg.SVGWriter.writeFeatures(SVGWriter.java:290)
at org.vfny.geoserver.wms.responses.map.svg.EncodeSVG.writeLayers(EncodeSVG.java:226)
at org.vfny.geoserver.wms.responses.map.svg.EncodeSVG.encode(EncodeSVG.java:93)
at org.vfny.geoserver.wms.responses.map.SVGMapProducer.writeTo(SVGMapProducer.java:97)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:188)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:465)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:247)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.vfny.geoserver.wms.servlets.WmsDispatcher.doResponse(WmsDispatcher.java:146)
at org.vfny.geoserver.wms.servlets.WmsDispatcher.doGet(WmsDispatcher.java:106)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:744)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
</ServiceException>
</ServiceExceptionReport>
For more information on JIRA, see:
