Returning XML file as shapefile
Key: GEOS-3381
URL: http://jira.codehaus.org/browse/GEOS-3381
Project: GeoServer
Issue Type: Bug
Environment: windows vista, 1.7.6
Reporter: Jonathan
Assignee: Andrea Aime
Maybe related to GEOS-3176.
Using this URL:
Ihttp://<host>:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.1.0&typename=national_parks&outputFormat=shape-zip&cql_filter=WITHIN(spatial_data,POLYGON((52.69039951342979 -3.2531133947651627,52.20277259477829 -3.2531133947651627,52.20277259477829 -4.1354672289895795,52.69039951342979 -4.1354672289895795,52.69039951342979 -3.2531133947651627)))
This should (and does) result in no data being returned. The problem is, rather than getting an XML file, GeoServer appears to return the XML as a zip MIME type so all browsers (Opera, firefox, IE tested) read the xml file as being zip. The contents are definitely xml.
