XML encoder in WFS 1.1 GetFeature leaks connection
Key: GEOS-3402
URL: http://jira.codehaus.org/browse/GEOS-3402
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Priority: Critical
Fix For: 1.7.7, 2.0-RC2
Sampo reported memory leak warning from GeoTools when running plain GetFeature 1.1 requests made by GeoEditor.
Instructed to add -Dgt2.jdbc.trace=true to the JVM he found this trace, reporting where the reader was grabbed from:
{code}
28 elo 13:35:55 WARN [geotools.jdb] - The unclosed reader originated on this stack trace
java.lang.Exception
at org.geotools.jdbc.JDBCFeatureReader.init(JDBCFeatureReader.java:161)
at org.geotools.jdbc.JDBCFeatureReader.<init>(JDBCFeatureReader.java:149)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:555)
at org.geotools.jdbc.JDBCFeatureStore.getReaderInternal(JDBCFeatureStore.java:206)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:508)
at org.geotools.data.store.ContentFeatureCollection.iterator(ContentFeatureCollection.java:272)
at org.geoserver.feature.RetypingFeatureCollection.iterator(RetypingFeatureCollection.java:47)
at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:56)
at org.geotools.data.crs.ReprojectFeatureResults.openIterator(ReprojectFeatureResults.java:108)
at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:332)
at org.geoserver.security.decorators.ReadOnlyFeatureCollection.iterator(ReadOnlyFeatureCollection.java:40)
at org.geotools.xml.Encoder.encode(Encoder.java:984)
at org.geotools.xml.Encoder.encode(Encoder.java:557)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:134)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at fi.tike.turvattuwfs.UrlAppenderFilter.doFilter(UrlAppenderFilter.java:44)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.jstripe.tomcat.probe.Tomcat55AgentValve.invoke(Tomcat55AgentValve.java:20)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
at java.lang.Thread.run(Thread.java:619)
{code}
The code in fact grabs an iterator, but it's generic enough that it won't check for closing the iterator if it was originated by a feature collection. Very bad, a server under WFS 1.1 request load will end up the connections before the garbage collector can kick the finalizers and free them
