Error - NoSuchElementException - Could not aquire feature:org.geotools.data.DataSourceException
Key: GEOS-3404
URL: http://jira.codehaus.org/browse/GEOS-3404
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.6
Environment: 1.7.6, windows Vista
Reporter: Jonathan
Assignee: Andrea Aime
I have a vector dataset stored in a MySQL table and am trying to do a WFS request on it with this URL:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.1.0&typename=urban_region&outputFormat=GML3&cql_filter=INTERSECT(spatial_data,POLYGON((52.78429031372057 -3.8953366279600257,52.78429031372057 -2.6543542064157517,51.812992538486576 -2.6543542064157517,51.812992538486576 -3.8953366279600257,52.78429031372057 -3.8953366279600257)))
However I get back this error:
<ows:ExceptionText>java.util.NoSuchElementException: Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT id_primary, CODE, LEGEND, FILE_NAME, NUMBER, NAME, NUMBER0, ADMIN_NAME, TYPE, FERRY_FROM, FERRY_TO, FERRY_TIME, FERRY_TYPE, RESTRICTIO, ACCESS, AMENDED, USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IMPERIAL, METRIC,
AsText(spatial_data) AS spatial_data FROM urban_region Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT id_primary, CODE, LEGEND, FILE_NAME, NUMBER, NAME, NUMBER0, ADMIN_NAME, TYPE, FERRY_FROM, FERRY_TO, FERRY_TIME, FERRY_TYPE, RESTRICTIO, ACCESS, AMENDED, USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IMPERIAL, METRIC, AsText(spatial_data) AS spatial_data FROM urban_region Error Performing SQL query: SELECT id_primary, CODE, LEGEND, FILE_NAME, NUMBER, NAME, NUMBER0, ADMIN_NAME, TYPE, FERRY_FROM, FERRY_TO, FERRY_TIME, FERRY_TYPE, RESTRICTIO, ACCESS, AMENDED, USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IMPERIAL, METRIC, AsText(spatial_data) AS spatial_data FROM urban_region
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near &apos;USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IM&apos; at line 1</ows:ExceptionText>
Strangely, if I change output format to GML2 (all other formats produce the first error, above), I get a slightly different error:
<ows:ExceptionText>
error:Translator error Translator error Error reading Features Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT id_primary, CODE, LEGEND, FILE_NAME, NUMBER, NAME, NUMBER0, ADMIN_NAME, TYPE, FERRY_FROM, FERRY_TO, FERRY_TIME, FERRY_TYPE, RESTRICTIO, ACCESS, AMENDED, USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IMPERIAL, METRIC, AsText(spatial_data) AS spatial_data FROM urban_region
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'USAGE, LOCATION, GIS, OWNER, NORTH, SOUTH, EAST, WEST, CLOCKWISE, ANTICLOCKW, IM' at line 1
I should note that the data displays fine in WMS, and that the same URL works perfectly when I use a different layer instead of urban_region.
This may be an error with the dataset (again, it display fine in WMS though), but a quick google search shows this error has occured before in GeoServer before being fixed.
