[Geoserver-devel] [jira] Created: (GEOS-3408) Bad shapefile DBF causes shapefile datastore to lock
                 Key: GEOS-3408
                 URL: http://jira.codehaus.org/browse/GEOS-3408
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.7.4
            Reporter: Jesse Eichar
            Assignee: Andrea Aime
            Priority: Minor
I have a shapefile with a DBF that geotools cannot open. See http://jira.codehaus.org/browse/GEOT-2689. But there is an additional bug. When viewing the shapefile with a spatial index generated the shapefile will deadlock after some time. I hit it with openlayers and uDig and after several renderings and getCapabilities it deadlocked. It might be a combination of concurrent usage, the index and the exception being thrown.
Not a critical issue without the index there seemed to be no problem.
If you want the data for testing take a look at the geotools bug. It is attached there.
