Virtual WMS layers
Key: GEOS-341
URL: http://jira.codehaus.org/browse/GEOS-341
Project: GeoServer
Type: New Feature
Components: WMS
Versions: 1.3.0-beta3
Environment: all
Reporter: dblasby
Assigned to: Gabriel Roldán
Fix For: 1.4
Currently, the layers in the WMS are 1:1 with the FeatureTypes (and that FeatureType's default style).
It would be great if you could create an (unqueryable) layer based on an SLD. This would be an SLD with a set of NamedStyles in it.
For a more concrete example, I have a nice TIGER map. Its composed of a few 'base' layers (ie. roads, parks, and lakes) which I have a set of Styles for. I'd like to have Geoserver serve this up as an easy-to-grab single layer.
Basically:
1. The user creates an SLD based on a set of NamedStyles (or, if you want to be even more tricky any SLD)
2. The user also provides a name for this layer
3. Geoserver WMS then advertises this layer, with these restrictions:
a) its unqueriable (or you can have it try to query all the sublayers)
b) you cannot re-style the layer. If you try to restyle the layer, it doesnt actually change the appearance. (it possible to remove this restriction, but I think it would be pretty complex for everyone involved. Basically, you'd have to make a big feature collection of ALL the sub-layer FeatureTypes. Yuck!)
In the end you're converting a request like this:
layers=layer1,layer2,layer3,layer4&styles=style1,style2,style3,style4
into:
layers=my_virtual_layer
For my concrete TIGER example, lets say someone one to put a fireHydrant layer on the TIGER set. Currently, they have to do this:
layers=giant_polygon,poly_landmarks,finalRoads,point_landmarks,fireHydrant
styles=....
With the virtual layer they could just request:
layers=tiger_basemap,fireHydrant
styles=default,myFireHydrantStyle
For more information on JIRA, see:
