geoserver RC1 WMS bug with new raster data
Key: GEOS-3424
URL: http://jira.codehaus.org/browse/GEOS-3424
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0-RC1
Environment: windows 2003 32bit, JDK 1.6.0_15-b03
Reporter: Paul Hastings
Assignee: Andrea Aime
Fix For: 2.0-RC2
get a consistent failure with WMS GetCapabilities requests on 2.0 RC1:
<ServiceExceptionReport version="1.1.1">
<ServiceException>Translator error
Translator error
Error occurred trying to write out metadata for layer: dem null
</ServiceException>
</ServiceExceptionReport>
it only seems to occur after adding in new raster data. if i remove the newly
added raster layers, it works as expected. it also works w/existing raster data
(from previous 1.7.x install).
Andrea Aime (via email list) reports
"I've just reproduce it, it happens because the UI does not force the
user to fill in the metadata URL format, but the caps code needs it.
Set "text/plain" in the format and you'll be good"
thanks.
