Exception trying to access coverage html representation
Key: GEOS-3431
URL: http://jira.codehaus.org/browse/GEOS-3431
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0-RC2
Working on the URL manglers I've stumbled into the following stack trace accessing:
{code}
9 set 16:23:07 WARN [/geoserver] - Exception intercepted
java.io.IOException: Template processing error Expression properties is undefined on line 2, column 13 in CoverageInfo.ftl.
at org.restlet.ext.freemarker.TemplateRepresentation.write(TemplateRepresentation.java:115)
at com.noelios.restlet.http.HttpServerCall.writeResponseBody(HttpServerCall.java:342)
at com.noelios.restlet.http.HttpServerCall.sendResponse(HttpServerCall.java:306)
at com.noelios.restlet.ext.servlet.ServletCall.sendResponse(ServletCall.java:306)
at com.noelios.restlet.http.HttpServerConverter.commit(HttpServerConverter.java:90)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:130)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.geoserver.rest.RESTDispatcher.handleRequest(RESTDispatcher.java:50001)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
{code}
Given the right template has been located I don't think this has anything to do with the modification I'm performing.
Where are those "properties" coming from?
