[Geoserver-devel] [jira] Created: (GEOS-3440) Default data dir does not survive a restart
                 Key: GEOS-3440
                 URL: http://jira.codehaus.org/browse/GEOS-3440
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-RC1
            Reporter: David Winslow
            Assignee: Justin Deoliveira
I'm using the default data directory via the jetty:run Maven task, with the following command:
{code}
$ mvn jetty:run -DGEOSERVER_DATA_DIR=/home/dwins/gs-release-data/ -Prestconfig,geosearch
{code}
Starting from a fresh copy of the data dir (an unmodified copy of what's in SVN, using svn export), I get the following:
{code}
$ curl http://localhost:8080/geoserver/rest/workspaces/default.json
{"workspace":{"name":"topp","dataStores":"http:\/\/localhost:8080\/geoserver\/rest\/workspaces\/default\/datastores.json","coverageStores":"http:\/\/localhost:8080\/geoserver\/rest\/workspaces\/default\/coveragestores.json"}}
{code}
If I then restart and try again, I get something different:
{code}
{"workspace":{"name":"nurc","dataStores":"http:\/\/localhost:8080\/geoserver\/rest\/workspaces\/default\/datastores.json","coverageStores":"http:\/\/localhost:8080\/geoserver\/rest\/workspaces\/default\/coveragestores.json"}}
{code}
Further restarts do not seem to keep changing the default workspace, so perhaps this is an issue with the data directory conversion code.
