[Geoserver-devel] [jira] Created: (GEOS-3443) 500 error on resource name collision through REST API
                 Key: GEOS-3443
                 URL: http://jira.codehaus.org/browse/GEOS-3443
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 2.0-RC1
            Reporter: Sebastian Benthall
            Assignee: Justin Deoliveira
When you use the REST API to change a resource's name, and pick a name that is already used by another resource, you get a 500 error in response.
sbenthall: What if there is a layer name collision?
jdeolive: The current implementation will return a 500. But this is a bug. It should handle this case and return a 403.
