java.lang.OutOfMemoryError with restconfig plugin
Key: GEOS-3444
URL: http://jira.codehaus.org/browse/GEOS-3444
Project: GeoServer
Issue Type: Bug
Components: WMS
Environment: Mac OSX
Reporter: Tim Schaub
Assignee: Andrea Aime
Using the restconfig plugin from http://gridlock.openplans.org/geoserver/trunk/ext-2009-09-11/ and the corresponding GeoServer nightly, I can somewhat regularly get out of memory errors on WMS GetMap requests. It looks like this only happens after making requests to /geoserver/rest/styles.
To reproduce, I run the styler app, change layers several times and pan around a bit. Usually I can see the exceptions in returned image tiles. The trace looks something like the following:
{code}
11 Sep 20:14:00 ERROR [geoserver.ows] -
java.lang.OutOfMemoryError: Java heap space
at java.awt.image.DataBufferByte.<init>(DataBufferByte.java:42)
at java.awt.image.Raster.createInterleavedRaster(Raster.java:253)
at java.awt.image.BufferedImage.<init>(BufferedImage.java:385)
at org.vfny.geoserver.wms.responses.ImageUtils.createImage(ImageUtils.java:83)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.prepareImage(DefaultRasterMapProducer.java:554)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:252)
at org.vfny.geoserver.wms.responses.map.metatile.MetatileMapProducer.produceMap(MetatileMapProducer.java:122)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:421)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:699)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
{code}
