[Geoserver-devel] [jira] Created: (GEOS-3520) CatalogImpl does not remove default namespace and workspace
                 Key: GEOS-3520
                 URL: http://jira.codehaus.org/browse/GEOS-3520
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.0-RC1
            Reporter: Gabriel Roldán
            Assignee: Justin Deoliveira
            Priority: Critical
             Fix For: 2.0-RC2
CatalogImpl does not remove default namespace and workspace, leaving them hanging until geoserver shuts downs. Problem is newly created stores might get confused by which one is the default workspace, when it does no longer exist but is available through getDefaultWorkspace()
The following is a patch with test cases. Justin I'm assigning to you to notice, feel free to reassign to me if the patch seems appropriate:
{code}
Index: src/main/java/org/geoserver/catalog/impl/CatalogImpl.java
--- src/main/java/org/geoserver/catalog/impl/CatalogImpl.java (revision 13354)
+++ src/main/java/org/geoserver/catalog/impl/CatalogImpl.java (working copy)
@@ -973,6 +973,12 @@
         if ( !getResourcesByNamespace(namespace, ResourceInfo.class ).isEmpty() ) {
             throw new IllegalArgumentException( "Unable to delete non-empty namespace.");
+ NamespaceInfo defaultNamespace = getDefaultNamespace();
+ if (namespace.equals(defaultNamespace)) {
+ namespaces.remove(null);
         namespaces.remove(namespace.getPrefix());
         removed(namespace);
@@ -1048,6 +1054,11 @@
         if ( !getStoresByWorkspace( workspace, StoreInfo.class).isEmpty() ) {
             throw new IllegalArgumentException( "Cannot delete non-empty workspace.");
+ WorkspaceInfo defaultWorkspace = getDefaultWorkspace();
+ if (workspace.equals(defaultWorkspace)) {
+ workspaces.remove(null);
         workspaces.remove( workspace.getName() );
         removed( workspace );
Index: src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java
--- src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java (revision 13354)
+++ src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java (working copy)
@@ -266,6 +266,30 @@
         assertTrue( catalog.getWorkspaces().isEmpty() );
+ public void testAutoSetDefaultWorkspace() {
+ catalog.add( ws );
+ assertEquals( 1, catalog.getWorkspaces().size() );
+ assertEquals(ws, catalog.getDefaultWorkspace());
+ public void testRemoveDefaultWorkspace() {
+ catalog.remove( ws );
+ assertNull(catalog.getDefaultWorkspace());
+ public void testAutoSetDefaultNamespace() {
+ catalog.add( ns );
+ assertEquals( 1, catalog.getNamespaces().size() );
+ assertEquals(ns, catalog.getDefaultNamespace());
+ public void testRemoveDefaultNamespace() {
+ catalog.remove( ns );
+ assertNull(catalog.getDefaultNamespace());
     public void testGetWorkspaceById() {
         catalog.add( ws );
         WorkspaceInfo ws2 = catalog.getWorkspace(ws.getId());
{code}
