GeoTIFF coverages will not render under 2.0rc1
Key: GEOS-3525
URL: http://jira.codehaus.org/browse/GEOS-3525
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0-RC1
Environment: SUSE LINUX Enterprise Server 9 (x86_64)
Apache Tomcat 5.5.27
java version "1.6.0_13"
Java(TM) SE Runtime Environment (build 1.6.0_13-b03)
Java HotSpot(TM) 64-Bit Server VM (build 11.3-b02, mixed mode)
Using Native JAI
Reporter: Joshua M. Thompson
Assignee: Andrea Aime
After upgrading from 1.7.6 to 2.0rc1 none of my GeoTIFF coverages will render. One of them is the NASA BlueMarble 500m set; the other is the TrueMarble 500m set. Any attempt to view these layers results in a WMS error and a backtrace:
org.geotools.feature.simple.SimpleFeatureImpl$Attribute cannot be cast to [Lorg.opengis.parameter.GeneralParameterValue;
java.lang.ClassCastException: org.geotools.feature.simple.SimpleFeatureImpl$Attribute cannot be cast to [Lorg.opengis.parameter.GeneralParameterValue;
at org.geotools.renderer.lite.StreamingRenderer.renderRaster(StreamingRenderer.java:2020)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:1928)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:1874)
at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1816)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1731)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:676)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1510)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1358)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:270)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:382)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:421)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:692)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:213)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:619)
I've tried running a nightly build from 09/17 but that did not help either.
