[Geoserver-devel] [jira] Created: (GEOS-3539) The DB property configuration files should be kept outside the JAR
                 Key: GEOS-3539
                 URL: http://jira.codehaus.org/browse/GEOS-3539
             Project: GeoServer
          Issue Type: Task
          Components: Hibernate catalog
    Affects Versions: 2.0-RC1, 2.0-beta2, 2.0-beta1, 2.0-alpha2, 2.0-alpha1
            Reporter: Alessio Fabiani
            Assignee: Alessio Fabiani
             Fix For: 2.0.x
Actually the DB property configuration files for the Hibernate Catalog are included into the JAR. They should be kept outside instead in order to give to the users the possibility to easily modify them without rebuilding the jar file.
