Group Layer disappeared during GWC cache routine
Key: GEOS-3557
URL: http://jira.codehaus.org/browse/GEOS-3557
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0-RC1
Environment: Ubuntu 9.04, JAI enabled in GeoServer
Reporter: Matt Bull
Assignee: Andrea Aime
Our TestGISBaseMap layer group just disappeared during a caching routine. The caching routine continued but was stopped before completion due to errors.
We noted that the 'OSR_10K_GB' layer has also disappered, which is potentially the cause of the layer group failure.
The Layer Group consisted of:
'OSR_10K_GB'
'OSR_25K_GB'
'OSR_50K_GB'
'OSR_250K_GB'
'PHIL_NAVIGATOR100K_GB'
'OSR_MINISCALE1MILLIONK_GB'
Stopping and then starting GeoServer failed to display the Layer Group, which was also missing from the GetCapabilities document.
I was able to recreate the layer using the same name and it reappeared but when I tried to create the Layer Group using the same name we got the following message 'java.lang.IllegalArgumentException: Layer group named 'TestGISBaseMap' already exists.'.
We then stopped geoserver with the OSR_10K_GB layer displaying again BUT not the TestGISBaseMap layer group. Upon restart, the TestGISBaseMap was still not visible from the UI.
The exception details are as follows.
Exception 1 (during caching and before stopping geoserver):
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
01 Oct 08:52:24 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Could not find layer TestGISBaseMap
at org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1072)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:178)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:70)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1092)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
01 Oct 08:52:25 ERROR [geoserver.ows] -
^C67345677 [Shutdown] INFO org.mortbay.log - Shutdown hook executing
67345760 [Shutdown] INFO /geoserver - Destroying Spring FrameworkServlet 'dispatcher'
67346309 [Shutdown] INFO /geoserver - Closing Spring root WebApplicationContext
01 Oct 08:52:27 ERROR [jdbc.JDBCMetaBackend] - Failed to unlock tile: Connection is broken [90067-104]
01 Oct 08:52:27 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
01 Oct 08:52:28 ERROR [jdbc.JDBCMetaBackend] - Failed to delete tile: Connection is broken [90067-104]
01 Oct 08:52:33 WARN [jdbc.JDBCMBWrapper] - SHUTDOWN call to JDBC resulted in: Connection is broken [90067-104]
01 Oct 08:52:35 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--e4447f0:123611d9d7a:-7ffe'
01 Oct 08:52:35 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-1a22e08d:1235c42b0f4:-7fd9'
01 Oct 08:52:35 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-1a22e08d:1235c42b0f4:-7fdb'
01 Oct 08:52:35 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-1a22e08d:1235c42b0f4:-7fdc'
01 Oct 08:52:35 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-1a22e08d:1235c42b0f4:-7fda'
67354762 [Shutdown] INFO /geowebcache - Destroying Spring FrameworkServlet 'geowebcache'
01 Oct 08:52:35 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
01 Oct 08:52:35 WARN [support.DisposableBeanAdapter] - Couldn't find a destroy method named 'stop' on bean with name 'gwcRuntimeStats'
01 Oct 08:52:35 INFO [storage.StorageBroker] - Destroying StorageBroker
01 Oct 08:52:35 WARN [jdbc.JDBCMBWrapper] - SHUTDOWN call to JDBC resulted in: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-118]
67356224 [Shutdown] INFO /geowebcache - Closing Spring root WebApplicationContext
67356638 [Shutdown] INFO org.mortbay.log - Shutdown hook complete
Exception 2 (Starting GeoServer):
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OSR_MINISCALE1MILLIONK_GB', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OSMiniscale'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer 'SDE.OSR_MINISCALE1MILLIONK_GB'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded store 'OS250k', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage store 'OS250k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OSR_250K_GB', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OS250k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer 'SDE.OSR_250K_GB'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded store 'OS50k', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage store 'OS50k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OSR_50K_GB', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OS50k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer 'SDE.OSR_50K_GB'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded store 'OS10k', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage store 'OS10k'
01 Oct 08:54:20 WARN [org.geoserver] - Failed to load coverage 'OSR_10K_GB'
com.thoughtworks.xstream.converters.ConversionException: : no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9 : : no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9
---- Debugging information ----
message : : no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9
cause-exception : com.thoughtworks.xstream.io.StreamException
cause-message : : no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9
class : org.geoserver.catalog.impl.CoverageInfoImpl
required-type : org.geotools.coverage.grid.GridGeometry2D
line number : 53
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:89)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:76)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:246)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:218)
at org.geoserver.config.util.XStreamPersister$ResourceInfoConverter.doUnmarshal(XStreamPersister.java:1218)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:162)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:82)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:33)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:420)
at org.geoserver.config.GeoServerLoader.depersist(GeoServerLoader.java:733)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:589)
at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:154)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:125)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: com.thoughtworks.xstream.io.StreamException: : no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:80)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:137)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:124)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.hasMoreChildren(AbstractPullReader.java:78)
at org.geoserver.config.util.XStreamPersister$GridGeometry2DConverter.unmarshal(XStreamPersister.java:902)
... 100 more
Caused by: java.io.EOFException: no more data available - expected end tags </transform></grid></coverage> to close start tag <transform> from line 45 and start tag <grid> from line 40 and start tag <coverage> from line 1, parser stopped on TEXT seen ...</transform>\n <crs... @53:9
at org.xmlpull.mxp1.MXParser.fillBuf(MXParser.java:3035)
at org.xmlpull.mxp1.MXParser.more(MXParser.java:3046)
at org.xmlpull.mxp1.MXParser.parseStartTag(MXParser.java:1738)
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1127)
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:63)
... 105 more
01 Oct 08:54:20 INFO [org.geoserver] - Loaded store 'OS25k', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage store 'OS25k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OSR_25K_GB', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'OS25k'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer 'SDE.OSR_25K_GB'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded store 'Philips Navigator 100k Colour Raster', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage store 'Philips Navigator 100k Colour Raster'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'PHIL_NAVIGATOR100K_GB', enabled
01 Oct 08:54:20 INFO [org.geoserver] - Loaded coverage 'Philips Navigator 100k Colour Raster'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer 'SDE.PHIL_NAVIGATOR100K_GB'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer group 'tasmania'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer group 'spearfish'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer group 'OSBaseMaps'
01 Oct 08:54:20 INFO [org.geoserver] - Loaded layer group 'TestGISBaseMap'
01 Oct 08:54:21 INFO [org.geoserver] - Loaded service 'wcs', enabled
01 Oct 08:54:21 INFO [org.geoserver] - Loaded service 'wfs', enabled
01 Oct 08:54:21 INFO [org.geoserver] - Loaded service 'wms', enabled
01 Oct 08:54:22 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
01 Oct 08:54:22 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms
01 Oct 08:54:22 INFO [storage.DefaultStorageFinder] - ******************************************************************************************************************************
01 Oct 08:54:22 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /gisdata/geoserver/data_dir, using it as the default prefix. ***
01 Oct 08:54:22 INFO [geowebcache.GeoWebCacheDispatcher] - set TileLayerDispatcher
01 Oct 08:54:22 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
01 Oct 08:54:22 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
01 Oct 08:54:22 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WFS_URL
01 Oct 08:54:22 INFO [util.ApplicationContextProvider] - Reverting to null
01 Oct 08:54:22 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOWEBCACHE_WFS_FILTER
01 Oct 08:54:22 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms, regex filter
01 Oct 08:54:22 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 6 paths
21022 [main] INFO org.mortbay.log - Opened /home/gisadmin/GIS_PRODUCTION/geoserver-2.0-RC1/logs/2009_10_01.request.log
21086 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
Exception 3 (after recreating layer and creating a new empty layer group):
01 Oct 09:21:46 INFO [org.geoserver] - Loaded workspace 'cite'
01 Oct 09:21:46 INFO [org.geoserver] - Loaded workspace 'tiger'
01 Oct 09:21:46 INFO [org.geoserver] - Loaded store 'nyc', enabled
01 Oct 09:21:46 INFO [org.geoserver] - Loaded data store 'nyc'
01 Oct 09:21:47 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'giant_polygon', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'nyc'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'giant_polygon'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'poi', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'poi'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'poly_landmarks', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'tiger_roads', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'tiger_roads'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded workspace 'sde'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded workspace 'topp'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded data store 'taz_shapes'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'tasmania_cities', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'tasmania_roads', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'tasmania_state_boundaries', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'tasmania_state_boundaries'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'tasmania_water_bodies', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'tasmania_water_bodies'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded store 'states_shapefile', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded data store 'states_shapefile'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'states', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'states_shapefile'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'states'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded workspace 'sf'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded store 'sf', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded data store 'sf'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'archsites', enabled
01 Oct 09:21:47 INFO [org.geoserver] - Loaded feature type 'sf'
01 Oct 09:21:47 INFO [org.geoserver] - Loaded layer 'archsites'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'bugsites', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'sf'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'bugsites'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'restricted', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'restricted'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'roads', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'roads'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'streams', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'streams'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'sfdem', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'sfdem'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'sfdem'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded workspace 'nurc'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'img_sample2', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'Pk50095', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'img_sample2'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'Pk50095'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'mosaic', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'mosaic'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'mosaic'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'worldImageSample', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'worldImageSample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'Img_Sample'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded workspace 'Test'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'Oracle64bitVector', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded data store 'Oracle64bitVector'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'OSMMTOPO_TOPO_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'Oracle64bitVector'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSMMTOPO_TOPO_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded feature type 'OSMMTOPO_ANNO_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSMMTOPO_ANNO_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'OSMiniscale', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'OSMiniscale'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSR_MINISCALE1MILLIONK_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSMiniscale'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSR_MINISCALE1MILLIONK_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'OS250k', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'OS250k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSR_250K_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OS250k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSR_250K_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'OS50k', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'OS50k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSR_50K_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OS50k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSR_50K_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'OS10k', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'OS10k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSR_10K_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OS10k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSR_10K_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'OS25k', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'OS25k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OSR_25K_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'OS25k'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.OSR_25K_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded store 'Philips Navigator 100k Colour Raster', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage store 'Philips Navigator 100k Colour Raster'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'PHIL_NAVIGATOR100K_GB', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded coverage 'Philips Navigator 100k Colour Raster'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer 'SDE.PHIL_NAVIGATOR100K_GB'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer group 'tasmania'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer group 'spearfish'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer group 'OSBaseMaps'
01 Oct 09:21:48 INFO [org.geoserver] - Loaded layer group 'TestGISBaseMap'
01 Oct 09:21:48 WARN [org.geoserver] - Failed to load layer group 'TestGISBaseMapTest.xml'
java.lang.NullPointerException
at org.geoserver.catalog.impl.CatalogImpl.resolve(CatalogImpl.java:1468)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:812)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:637)
01 Oct 09:21:48 INFO [org.geoserver] - Loaded service 'wcs', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded service 'wfs', enabled
01 Oct 09:21:48 INFO [org.geoserver] - Loaded service 'wms', enabled
01 Oct 09:21:48 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
01 Oct 09:21:48 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms
01 Oct 09:21:48 INFO [storage.DefaultStorageFinder] - ******************************************************************************************************************************
01 Oct 09:21:48 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /gisdata/geoserver/data_dir, using it as the default prefix. ***
01 Oct 09:21:49 INFO [geowebcache.GeoWebCacheDispatcher] - set TileLayerDispatcher
01 Oct 09:21:49 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
01 Oct 09:21:49 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
01 Oct 09:21:49 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WFS_URL
01 Oct 09:21:49 INFO [util.ApplicationContextProvider] - Reverting to null
01 Oct 09:21:49 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOWEBCACHE_WFS_FILTER
01 Oct 09:21:49 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms, regex filter
01 Oct 09:21:49 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 6 paths
8200 [main] INFO org.mortbay.log - Opened /home/gisadmin/GIS_PRODUCTION/geoserver-2.0-RC1/logs/2009_10_01.request.log
8213 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
45322 [btpool0-7] INFO /geoserver - Initializing Spring FrameworkServlet 'dispatcher'
45517 [btpool0-7] INFO org.apache.wicket.Application - [GeoServerApplication] init: Wicket core library initializer
45521 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
45522 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
45523 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
45524 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
45526 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
45527 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
45529 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
45531 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
45532 [btpool0-7] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
45532 [btpool0-7] INFO org.apache.wicket.Application - [GeoServerApplication] init: Wicket extensions initializer
45539 [btpool0-7] INFO org.apache.wicket.protocol.http.WebApplication - [GeoServerApplication] Started Wicket version 1.3.6 in deployment mode
45646 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
45650 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
45657 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
45727 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
45728 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
45732 [btpool0-7] INFO org.apache.wicket.resource.PropertiesFactory - Loading properties files from org.geoserver.web.GeoServerApplication$GeoServerResourceStreamLocator$1@anonymised.com
72066 [btpool0-0] INFO org.apache.wicket.RequestListenerInterface - registered listener interface [RequestListenerInterface name=INewBrowserWindowListener, method=public abstract void org.apache.wicket.markup.html.INewBrowserWindowListener.onNewBrowserWindow()]
