Disabling the GeoServer console
Key: GEOS-3561
URL: http://jira.codehaus.org/browse/GEOS-3561
Project: GeoServer
Issue Type: Wish
Components: Configuration
Affects Versions: 1.7.x, 2.0.x
Environment: Applies to all platforms.
Reporter: Sampo Savolainen
Assignee: Justin Deoliveira
For security purposes, it would be a good idea to have the option to disable the configuration console. Currently, the console runs always even when in production the configuration rarely changes. In cases where there are separate (development/)test/production environmenta, the production server might never need to have the console enabled as configuration can be injected through the data directory.
One good method of disabling the console would be a system property. (For example, adding -Dgeoserver.console=disabled to the java parameters). This allow using the same geoserver deployment (.war) in both test and production.
