Requesting multiple layers using a single CQL filter returns an error
Key: GEOS-3562
URL: http://jira.codehaus.org/browse/GEOS-3562
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.7.6
Environment: Geoserver 1.7.6 running inside Apache Tomcat/6.0.16 with JVM Version Þ1.6.0_05-b13 on Windows 2003 x86
Reporter: Gissur Þórhallsson
Assignee: Andrea Aime
Priority: Minor
Attachments: error.log, error.png, request.txt
If I post a request (see attachment request.txt) requesting multiple layers using a single CQL filter to the WMS service running under to geoserver 1.7.6 I get an image with an errormessage (see attached image) and the following gets logged into geoserver.log (again, see attachment error.log).
This same requests works fine under geoserver 1.6.2 and this issue is kind of preventing me from upgrading at the moment.
The CQL filter is something of a behemoth I am aware, but the layers are set up so that it applies equally to all of them - that was at least the behavior I discovered when I was setting this up originally.
