[Geoserver-devel] [jira] Created: (GEOS-3571) geoserver.log and *.properties files appear in the wrong place
                 Key: GEOS-3571
                 URL: http://jira.codehaus.org/browse/GEOS-3571
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-RC1
         Environment: This has been tested with Tomcat 6.0.20 on both Solaris and Linux.
            Reporter: Sampo Savolainen
            Assignee: Andrea Aime
            Priority: Minor
These files appear at $PWD/logs when geoserver is started. They should appear relative to the server home directory ($CATALINA_BASE in tomcat). This issue did not happen with 1.7.6.
DEFAULT_LOGGING.properties
GEOTOOLS_DEVELOPER_LOGGING.properties
GEOSERVER_DEVELOPER_LOGGING.properties
PRODUCTION_LOGGING.properties
VERBOSE_LOGGING.properties
geoserver.log
     [ http://jira.codehaus.org/browse/GEOS-3571?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Sampo Savolainen reopened GEOS-3571:
I was told the fix should be in the yet unreleased, but downloadable RC2. However, at least the version of RC2 I got did not fix the issue.
Here is the SHA1 sum of the used geoserver.war. It was downloaded Oct 15th from sourceforge in package geoserver-2.0-RC2-war.zip.
a4069ce9722397fcff5740f93e2b06ab26bdad3c geoserver.war
                Key: GEOS-3571
            Project: GeoServer
         Issue Type: Bug
           Priority: Minor
            Fix For: 2.0-RC2
geoserver.log
