Error while trying to "Apply" or "Load" data config changes
Key: GEOS-359
URL: http://jira.codehaus.org/browse/GEOS-359
Project: GeoServer
Type: Bug
Versions: 1.3-rc1
Environment: Windows, Java 5.0, Tomcat 5.0
Reporter: Scott Pezanowski
Assigned to: dblasby
I just installed Geoserver with Tomcat 5.0. I am running the administration
tool and trying to add data. Anytime I click the "apply"
button or the "load" button when trying to add data, I get the error below.
I seem to be able to add Namespaces, and Stores fine but then when I click "Apply", I get
this error. Does anyone know what's going on here?
Scott
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that
prevented it
from fulfilling this request.exception
javax.servlet.ServletException: 0
org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:545)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:486)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
javax.servlet.http.HttpServlet.service(HttpServlet.java:856)root cause
java.lang.ArrayIndexOutOfBoundsException: 0
org.vfny.geoserver.global.Log4JFormatter.init(Log4JFormatter.java:193)
org.vfny.geoserver.global.GeoServer.load(GeoServer.java:351)
org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:70)
org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
javax.servlet.http.HttpServlet.service(HttpServlet.java:856)note The full stack trace of the root cause is available in
the
Tomcat logs.
Apache Tomcat/5.0.19
For more information on JIRA, see:
