No native Java ImageIO + Native JPEG acceleration enabled anyways + metatiled wms output = boom!
Key: GEOS-3592
URL: http://jira.codehaus.org/browse/GEOS-3592
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0-RC2
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.0
In the above situation the workaround for the JDK writer does not enable. The code passing down the hint to use native acceleration should check if the native acceleration is available in the first place, or else the ImageWriter has to do that (possibly once and store the results in a static variable)
