WMS query fails with ORA-13208 and ORA-06512 exceptions
Key: GEOS-3594
URL: http://jira.codehaus.org/browse/GEOS-3594
Project: GeoServer
Issue Type: Bug
Components: Oracle, WMS
Affects Versions: 2.0-RC2
Environment: Windows XP, Oracle 11g, Oracle NG drivers for GeoServer.
Reporter: Pavel Golodoniuc
Assignee: Andrea Aime
Attachments: ER_TEST.sql, Exception.txt, GSML_MAPPEDFEATURE_SIMPLE.sql
In an Oracle database I have created two views from attached GSML_MAPPEDFEATURE_SIMPLE.sql and ER_TEST.sql and added corresponding records into USER_SDO_GEOM_METADATA:
SELECT * FROM USER_SDO_GEOM_METADATA;
TABLE_NAME COLUMN_NAME DIMINFO SRID
ER_TEST LOCATION MDSYS.SDO_DIM_ELEMENT(MDSYS.SDO_DIM_ELEMENT(longitude,-180,180,0.000001),MDSYS.SDO_DIM_ELEMENT(latitude,-90,90,0.000001)) 8311
GSML_MAPPEDFEATURE_SIMPLE LOCATION MDSYS.SDO_DIM_ELEMENT(MDSYS.SDO_DIM_ELEMENT(longitude,-180,180,0.000001),MDSYS.SDO_DIM_ELEMENT(latitude,-90,90,0.000001)) 8311
In fact, ER_TEST view is a simplified version of the GSML_MAPPEDFEATURE_SIMPLE and exposes just two fields (ID and SDO_GEOMETRY). In both cases the data is coming from the same table, the same filter conditions and joins are applied.
Then I have successfully created two layers in GeoServer with absolutely the same settings. Simple GetFeature WFS requests like http://localhost:9090/geoserver/wfs?request=GetFeature&typeName=pirsa:ER_TEST&maxFeatures=10 work perfectly in both cases. But for some reason the WMS is only producing correct output for GSML_MAPPEDFEATURE_SIMPLE feature type. When attempting to query WMS for ER_TEST (http://localhost:9090/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=pirsa:ER_TEST&styles=&bbox=129.102,-38.058,141.0,-26.003&width=505&height=512&srs=EPSG:4283&format=image/png) GeoServer generates an error (see Exception.txt).
What is so different in these two so similar views that causes this unexpected behaviour?
