[Geoserver-devel] [jira] Created: (GEOS-36) Fix enabling of services
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-36
Here is an overview of the issue:
        Key: GEOS-36
    Summary: Fix enabling of services
       Type: Task
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
   Fix Fors:
             1.1.1
   Versions:
             1.1beta
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Mon, 29 Dec 2003 3:54 PM
    Updated: Mon, 29 Dec 2003 3:54 PM
Description:
In the services.xml file WMS and WFS both have an enabled field that can be set to true. Unfortunately this does not yet do anything. If enabled is set to false then users should not be able to access the WMS or WFS portion of the server.
We should also consider at the very least being able to set WFS transactions to false. That way not just any user could come along and change things. One hacky way of doing this is to just have a validation rule that rejects everything. A much better solution would be to allow some sort of authentication or limiting to ip addresses, but that should be another task. We could also consider a geoserver specific parameter of a password or something, as an attribute or element of the transaction request.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
