[Geoserver-devel] [jira] Created: (GEOS-3601) Uploading coverage fails
                 Key: GEOS-3601
                 URL: http://jira.codehaus.org/browse/GEOS-3601
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 1.7.7
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
From geoserver-devel:
I'm using geoserver 1.7.7
I'm trying to add a coverage as it is described in the example: http://docs.geoserver.org/1.7.x/en/user/extensions/rest/coverage_xml.html#coverage-xml
I ran into two problems, first, just using the example, simply does not work, therefore I had to change CoverageDimension.java as shown below
Then, when I got this work, I could not restart the geoserver anymore because I got exceptions when loading the layer just added, therefore I had to change LegacyCoverageInfoReader.java as shown below
