[Geoserver-devel] [jira] Created: (GEOS-3617) SQL to auto discover PK fields on views when JDBC getPrimaryKeys fails
                 Key: GEOS-3617
                 URL: http://jira.codehaus.org/browse/GEOS-3617
             Project: GeoServer
          Issue Type: Improvement
          Components: Oracle
    Affects Versions: 2.0.0
         Environment: OracleNG
            Reporter: Bryan Hall
            Assignee: Andrea Aime
            Priority: Minor
When using views to access data in a table, the JDBC getPrimaryKeys call fails to indicate the correct PK column - sometimes. I have not been able to determine why it works sometimes, and not others - and assume it is an Oracle bug.
Here is SQL that could be used to probe the db to return the PK (if any) when the getPrimaryKeys call fails. It requires no special privilages, and should just be called by the view schema owner. As long as the view and base table use the same name for the column, it will work. Substitute the desired values for 'GEOSERVER_RO' and 'AIRFIELD_SURFACE_AREA':
WITH source_table
       AS (SELECT b.owner, b.object_name
             FROM sys.ALL_OBJECTS a,
                    sys.ALL_OBJECTS b,
                    ( SELECT object_id, referenced_object_id
                           FROM public_dependency
                     START WITH object_id =
                                     (SELECT object_id
                                       WHERE owner = 'GEOSERVER_RO'
                                               AND object_name =
                                               AND object_type = 'VIEW')
                     CONNECT BY PRIOR referenced_object_id = object_id) c
            WHERE a.object_id = c.object_id
                    AND b.object_id = c.referenced_object_id
                    AND a.owner NOT IN ('SYS', 'SYSTEM')
                    AND b.owner NOT IN ('SYS', 'SYSTEM')
                    AND a.object_name <> 'DUAL'
                    AND b.object_name <> 'DUAL'
                    AND b.object_type = 'TABLE')
SELECT l.column_name, l.position
  FROM source_table s,
            all_constraints n
         JOIN
            all_cons_columns l
         ON l.owner = n.owner
            AND l.table_name = n.table_name
            AND l.constraint_name = n.constraint_name
WHERE n.constraint_type = 'P'
         AND n.table_name = s.object_name
         AND n.owner = s.owner;
