[Geoserver-devel] [jira] Created: (GEOS-362) PostGIS without GEOS
         Key: GEOS-362
         URL: http://jira.codehaus.org/browse/GEOS-362
     Project: GeoServer
        Type: Bug
    Reporter: dblasby
Assigned to: dblasby
     Fix For: 1.3.0
FYI,
  I accidentally had an experience using geoserver on postgis without GEOS support (I forgot to enable it when I compiled postgis). Before I enabled it, I never got a result back from geoserver, things just appeared to go and go. After I enabled it, everything was tickety-boo.
  Thank god there was a big "you don't have GEOS!" warning in the log, or I could have spent hours trying to figure out what was wrong with *UDIG* :slight_smile: (Turns out, it was fine.)
Paul
There's probably something wrong with the non-geos postgis reader.
For more information on JIRA, see:
