creating a geometryless ArcSDE table using REST resolves in error
Key: GEOS-3635
URL: http://jira.codehaus.org/browse/GEOS-3635
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Affects Versions: 2.0.0
Reporter: Bart van den Eijnden
Assignee: Andrea Aime
I am trying to use the REST interface of GS 2.0 to create geometryless
tables for ArcSDE, but I am getting:
Unable to transform referenced envelope, crs has not yet been provided.
I have been able to create the namespace as well as the store, and I've
verified they are working ok by manually creating a featureType using the
admin tool.
The request I am trying is:
function createFeatureType($datastore, $name, $nativeName) {
$xml =
"<featureType><name>".$name."</name><nativeName>".$nativeName."</nativeName>";
$xml .= "<projectionPolicy>FORCE_DECLARED</projectionPolicy>";
$xml .= "<srs>EPSG:28992</srs>";
$xml .=
"<latLonBoundingBox><minx>2.0</minx><maxx>6.0</maxx><miny>52.0</miny><maxy>56.0</maxy></latLonBoundingBox>";
$xml .= "</featureType>";
$this->doPOST("workspaces/".$this->mszWorkspace."/datastores/".$datastore."/featuretypes",
$xml);
The stack trace I am getting is:
org.geoserver.rest.RestletException: java.lang.NullPointerException:
at
org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:329)
at
org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:118)
at org.restlet.Finder.handle(Finder.java:296)
at
org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at
com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at
org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at
at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.NullPointerException: Unable to transform referenced
at
org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:618)
at
org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:584)
at
org.geoserver.catalog.CatalogBuilder.initFeatureType(CatalogBuilder.java:551)
at
org.geoserver.catalog.rest.FeatureTypeResource.handleObjectPost(FeatureTypeResource.java:93)
at
org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:115)
... 56 more
