Introduce EMF bindings for the management of WCS1.0.0 requests/responses also
Key: GEOS-3636
URL: http://jira.codehaus.org/browse/GEOS-3636
Project: GeoServer
Issue Type: Improvement
Components: WCS
Reporter: Alessio Fabiani
Assignee: Alessio Fabiani
Fix For: 2.0.1, 2.0.x, 2.1.x
Aligning WCS 1.0.0 to use the GeoTools WCS EMF Bindings and WCS1.0.0 XML parser, similar to the WCS 1.1.x module.
The common WCS classes will be left to the shared WCS module, while the specific WCS 1.0.0 protocol ones will be handeld through another brand new WCS1_0 module. The latter will make use of GeoTools EMF bindingns and XML WCS parser in order to handle the WCS requests and reponses.
