[Geoserver-devel] [jira] Created: (GEOS-3639) Buld failure in arcsde extension on 2.0.x branch
                 Key: GEOS-3639
                 URL: http://jira.codehaus.org/browse/GEOS-3639
             Project: GeoServer
          Issue Type: Bug
          Components: ArcSDE
    Affects Versions: 2.0.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Blocker
Failing on Hudson as well.
{code}
[INFO] Building ArcSDE DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory /home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/target
[INFO] [resources:resources]
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory /home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/src/main/resources
[INFO] [compiler:compile]
[INFO] Compiling 2 source files to /home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/src/main/java/org/geoserver/web/data/store/arcsde/ArcSDECoverageStoreEditPanel.java:[52,31] package org.geotools.arcsde.gce does not exist
/home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/src/main/java/org/geoserver/web/data/store/arcsde/ArcSDECoverageStoreEditPanel.java:[304,50] cannot find symbol
symbol : variable ArcSDERasterFormat
location: class org.geoserver.web.data.store.arcsde.ArcSDECoverageStoreEditPanel.ArcSDEStoreListModel
/home/car605/geoserver/src with spaces/geoserver-2.0.x/src/extension/arcsde/src/main/java/org/geoserver/web/data/store/arcsde/ArcSDECoverageStoreEditPanel.java:[357,35] cannot find symbol
[INFO] Total time: 6 minutes 48 seconds
[INFO] Finished at: Tue Nov 10 12:29:58 WST 2009
[INFO] Final Memory: 51M/73M
{code}
