[Geoserver-devel] [jira] Created: (GEOS-3654) Set range of values to Transparent
                 Key: GEOS-3654
                 URL: http://jira.codehaus.org/browse/GEOS-3654
             Project: GeoServer
          Issue Type: Improvement
          Components: Image mosaic JDBC
    Affects Versions: 2.0.x
         Environment: Java/Ecw
            Reporter: Tisham Dhar
            Assignee: Andrea Aime
            Priority: Minor
For lossy compresses formats such as ECW and JPEG mosaicing and serving overlapping datasets can be quite a hassle due to imperfect black edges.
The solution in most desktop viewing softwares (ESRI/ERMapper/Erdas/WorldWind) is to set a range of values near 0 to transparent. This is usually a subjective choice, the other option is to specify an exact extent cropping polygon and mask the data with the polygon.
Being able to set a range of values to transparent either via the SLD or the ImageMosaic plugin will be of great utility while serving these compressed formats.
